-   -   Odometer stopped working (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/764723-odometer-stopped-working.html)
PorscheNut924 08-07-2013 07:14 AM
Simple question...my speedometer is still working but the odometer is not. Where might the problem be and what should I do to diagnose and fix it? It's a 924S so the early style dash.
John_AZ 08-07-2013 07:35 AM
Usually a new gear.
OR you may get lucky and just have to slide the "loose-skipping" gear back in place and glue.
Be careful not to cross thread the speed O cable connection on the back of the speedometer.
Also, there is a delicate connection from the speedometer to the UP-Shift indicator on the dial next to the speedometer. This is the Hall Sensor connection.
DIY--Note Pelican sells the gears---Buy from Pelican
http://www.944online.com/pdf/944_Early_Odometer_Gear_Replacement.pdf
GL
J_AZ
PorscheNut924 08-07-2013 09:15 AM
Thanks. I'll take the gauges out and have a look at it, and return if I have more questions.
John_AZ 08-07-2013 09:18 AM
I did not have to remove the "needle" to fix mine. The gear slid sideways. I put a drop of epoxy on the shaft to keep it in place ----5++ years ago and still OK.
J_AZ
Gawernator 08-08-2013 12:00 AM
John's a lucky one in that case. Some of us have performed a full repair and still get issues.. :(
