Annoying Recurring Problem
Alright, so I am finally posting here after spending way too much time and money because of one issue with my 1987 924S. Honestly, the rest of the car has been brilliantly reliable, but I have been driven to the point where I'm contemplating selling the car.
Every few weeks, the strut used to adjust the air-conditioning compressor shears a bolt. Every few months, the bolt holding the compressor itself shears and twice has shattered the little piece of metal that it screws through (on the compressor). I can no longer afford to continue replacing the compressor and have the car rendered un-drivable nearly once a month.
I am at my wit's end trying to figure out why this problem won't go away. Without having driven other 924s and 944s, I would say that my car must be vibrating more than it is supposed to and causing the weight of the compressor to eventually break either itself or the bolts that are holding it onto the vehicle. Has anyone else experienced a similar issue with their vehicles? If so, what did you do to finally fix it? Without knowing, I would guess (but have not checked) that my balance belts are off. I know that I replaced the motor mounts when I got the vehicle a couple years ago, which helped the problem to an extent.
Thank you very much for any information you can provide. I have looked at other threads detailing the balance belts, so I think I will have them checked unless someone can tell me that they aren't the problem.
Guards Red over Black 1987 Porsche 924S
Old 08-11-2013, 04:29 PM
AFM #725
Gawernator's Avatar
Are you installing them? If you tension the A/C belt after bolting down the compressor mounts etc and not after adjusting the tension, then exactly what you describe will happen. Even happened to me because of a PO
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 08-11-2013, 04:49 PM
Hmm.... That could be the case. What is the proper method of installing the strut/ compressor? Adjust the compressor so that the belt is tensioned, tighten the bolt, then install the strut?
Old 08-11-2013, 07:59 PM
Volhv's Avatar
1-Loosen both compressor mount bolts.
2-Loosen both tensioning strutt mounting bolts.
3-Tension belt, and tighten the jamb nuts on the strutt.
4-Torque the compressor and strutt mounting bolts.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 08-11-2013, 09:09 PM
AFM #725
Gawernator's Avatar
Yup! If you are doing that out of order, it breaks things.
Old 08-11-2013, 09:21 PM
Back from Beyond
Yup. Just remember the compressor needs to be mobile until belt tension is set. Otherwise tensioning the belt forces the mount to flex.
Old 08-11-2013, 10:21 PM
Patrick
pfarah's Avatar
Makes perfect sense to me; you always want to adjust the moving component prior to the fixed one.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 08-12-2013, 03:30 AM
Oh man...What now?
iplagolf's Avatar
Use a grade 8 bolt. More shear strength and what they said.
Me and Porsche's go together like cocaine and waffles. Those don't go together. Well, peanut butter and women. Don't you mean jelly? You put jelly on women? (Ricky Bobby, Talladega Nights) 1985.5 944 Alpine white
Old 08-12-2013, 04:50 AM
That makes sense. No wonder I was having so many issues. Thank you very much!
Old 08-12-2013, 09:30 AM
Tags
air-conditiong , vibration
