-   -   speed sensor stuck (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/766415-speed-sensor-stuck.html)
rgrennen 08-16-2013 03:34 PM
speed sensor stuck
hey all, so i was in the process of replacing my speed/reference sensor and all was going smooth until i reached the speed sensor removal. basically i got the speed sensor out just far enough that i can see the o-ring. it will not budge any further. it rotates freely in the bracket but will not come out or go back in. I'm baffled.
John_AZ 08-16-2013 05:56 PM
Happens to many owners.
A link:
Rennlist Discussion Forums - View Single Post - Time for a new clutch…
The full post:
Time for a new clutch… - Page 2 - Rennlist Discussion Forums
Do not be baffled.
I enjoyed this post especially entry #40
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/457162-my-new-944-reference-sensor-dillema-need-some-advice-porsche-gurus.html
GL & welcome,
J_AZ
Slam 08-16-2013 11:22 PM
Two schools of thought:
PB Blaster, gentle persuasion, twist and push, twist and pull, apply a little heat, lather, rinse repeat.
My method: BFH, giant screwdriver, pry bar, brute force, ignorance. Break that bracket and you're done in 5 min.
First method worked on my 84. Second method on wifey's 87.
At the first signs of frustration go directly to method two. Trust me...
