muffler hook mistake
I discovered today I am the owner of the muffler hook #13 in this pic:
I discovered this by cutting/drilling/destroying the bolt and hex nut, only to find the bolt is somehow secured to the body at the top - not a captive nut that I know of, not a hex head. it looks like a rounded thin cap.
what is this threaded component? how is it attached? what can replace it?
87 944 NA
Old 08-25-2013, 03:43 PM
Volhv's Avatar
It's a stud welded to the body.
If it breaks, drill it out and put a bolt in instead.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 08-25-2013, 05:37 PM
mhariush's Avatar
I just happen to have my exhaust system out.
It it's #9 you're talking about, then...#5 goes over the torque tube, bolts into #6. #8 goes on #6 and #9 hangs from #8.
Here's the new one from Porsche
And if you're referring to #12 they go on a bracket on the body like this
And these are the new ones (#12 and #13) from Porsche
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 08-25-2013, 06:08 PM
mhariush's Avatar
And as Volhv says, #13 is connected with a stud to the bracket. But the bracket can't be removed... Cut the stud, drill a hole and put a bolt through...
Old 08-25-2013, 07:33 PM
