he's Asking 1300.00
Found This Car here locally going up this weekend to physically inspect the car. Any thoughts on value? Costs for fuel repairs? Things to look For on specific Major problems? What do or should i expect from handling? Looking to make this car my mountain commuter personal thought for power? Currently Doing Research on the 924 these years for vw etc. Thanks Eveyone Not much knowledge on the 924 only info i have from seller "1976 Porsche with Martini package. Car is complete but does not run. Needs fuel injection and pump work. Dash is cracked . Body is straight." Has some maintence records WAS NOT HIS CAR Pictures car is a 6 out of 10
what's the last 5 digits of the VIN?
If it's 10193 whatever you do don't buy it |
Either way run, don't walk to a 944. A non-running 924 is not something to enjoy. You might think VW=cheap and easy WRONG!
I started with a 924 and I really enjoyed driving it. The fueal accumulator is a little tricky at times, but not impossible. I have seen these before. If I remember correctly, they made 1400 of these special edition 924s. You would think a limited edition car would be worth a lot more, but they aren't. I have seen them priced between $5000 and $800. To me, if you like the car and can do the work yourself, you can't go wrong with a $1300 car. At worse, you can replace the entire engine for $4-500. Parts are just as easy to get as 944 parts. I still have an engine for my first one in my shed. Good luck with it!
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car) |
The general rule when buying porsches is buy the nicest one you can afford. If you want a project, a running and driving one will keep you busy.
Cheap tires $300 Brake hoses $50 Wheel cylinders $50 Fuel pump $150 Rebuilt WUR $150 Cam belt kit $50 Intake boots (they will leak) $100 Oil change $30 Coolant flush $30 Fuel filter $20 Air filter $10 Ignition stuff $100 That's almost $1000 in stuff that you will need at a minimum. Once you're $2300+ into the car you have a car that is no longer supported by OEMs and Porsche is just chucking their stocks of 924 parts. A 4-speed car with about 80 flywheel HP in Denver. A car that will violently shake at idle and there's nothing you can do about it. Don't even think about AC for those hot days your car has been basking in the high plains sun. Keep your eyes out for a running and driving one if you really want to get into a 924. They were only partly galvanized through 79. You should be able to get into a pretty nice driving 80-82 for under 2k. Half the 924's you see for sale "need a fuel pump". Usually they need a lot more than a fuel pump. |
Here's a pretty good example (no affiliation) of the kind of 924 you want to buy if you're looking for a project
1981 Porsche 924 |
Engineer of profanity
1970 Porsche 911T Black 1990 Porsche 944 S2 Red on cashmere 1984 Porsche 928S Euro ROW GP white on black |
Back from Beyond
Having owned a few 924s, I agree with Jrboulder for the most part. That said, if that Martini was anywhere near me I'd be trying to get it into my shop - for about $500. But i have two 924 parts car to pull bits off. Have you driven a well sorted 924? They're sweet (in the true sense of the word) and charming. But don't buy unless you're prepared to do a lot of wrenching. And scouring the net looking for parts, many of which are NLA, as mentioned.
Still, I love the Martini model. And we love Mand's (my wife) 924... |
Thanks Guys, Going Up this Morning to Check It out. Keep You posted on the Outcome of Today.
Sorry to say it but every bit of plastic and rubber on that car is brittle and/or already broken. Having owned older 924/944/968 cars for 20 years, I wouldn't go near something like that again if my life depended on it.
In the UK genuine Martini cars are worth considerable more than regular 924. I obtained used fuel injection parts cheaply from eBay for a friends 924 that would run but was reluctant to start.
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
Patrick
I'm more of a rum and Coke guy....
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
AFM #725
I must be too young to get that joke
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Patrick
You're never too young to drink (LOL).
Back from Beyond
Shaken, not stirred.
Checked the car.
Busted Photo Looks 100 Times Better than the real condition. Sad Sad day parts car. |
AFM #725
Oh well bro
Welcome to Craigslist.
Back from Beyond
Which is why my standard offer is around $500...
