Got them out. They slid right out. Barely had to work them at all. Just used my hands. They were probably out when they did the clutch about 8 months ago so they hadn't seized up yet.
I noticed on the one being used as the speed sensor it had a dent on the top edge on one side. Clearance problem? Kind of hard to see in the image but here is a picture of it. Do you think I should check the bracket clearance?
The reference sensor continues to test up correctly. I was able to test it directly connected to the sensor. The reason why it wasn't working for me before was I was looking at the pins in reverse. I don' t know if my bracket is upside down but my connectors are the opposite of what is shown on Clark's page. I figured it out when I looked at the keyed part of the connector. The speed sensor continues to be dead.
Running Cars
06 Boxster S, 85 944, 83 928S
Project Cars
74 914, 74 911, 72 914, 66 911, 65 912
Old 09-09-2013, 04:44 PM
Rogue Tuning
Rogue_Ant's Avatar
Originally Posted by 9fourteen View Post
Which sensor will cause the tach to bounce? Or is it a combination of them both?
Both need to be working properly. (well, technically, the speed sensor could be partially working and the tach might still bounce - assuming a good reference sensor)
-Joshua
www.RogueTuning.com
Old 09-09-2013, 05:38 PM
Patrick
pfarah's Avatar
My old sensors tested within range but I think the magnets were just tired. The car came right back to life upon replacement.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 09-09-2013, 05:47 PM
Replaced both sensors and it fired right up.
Running Cars
Project Cars
Old 09-14-2013, 03:50 PM
GreenWater's Avatar
Awesome. Glad to hear your car is fixed.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 09-14-2013, 03:53 PM
Wink
Running, not sure if I would say fixed yet. This car is far from perfect and needs sorted out. I'm starting a list of things that need done. I just started a new thread for the next issue, engine is making a clicking sound.
Running Cars
Project Cars
Old 09-14-2013, 04:00 PM
