Which Vacuum lines do I need?
I need to change the AOS seals and some of the rubber lines underneath the intake manifold look cracked.
I'm wondering the name of them/a link so I can replace them. Also, totally unrelated, how do I change my signature line? lol |
To change you signature line, click on USER CP at the top of this page.
I don't have the vacuum hoses committed to memory. There should be a hose diagram on the right of your inner fender under the hood. Hose routing is also in Clarks garage. Clifton FUEL-13, Fuel and Vacuum Line Diagram (1985.5 and Newer N/A 944s) |
AFM #725
They are listed by name in the Pelican Parts Catalog, I.e. AOS Breather hose
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Get a kit and do em all
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
Which rubber lines? the hoses? or the hard vacuum lines? I replaced mine with new hard lines, got them by the foot from 944online (I know a lot people here don't like 944online, but they're not bad, if you find what you want there), and I also replaced the rubber hoses and did a venturi delete.
Are these for your NA or S? You def need some of these Y fittings: 928-573-727-02-M36 and some of the C elbows: 928-574-717-02-M5 I got these hardlines from 944online, i like to keep the car oem looking: 944online.com - Air / Fuel System Find Parts For Your Porsche 944 And Get Your Car Back On The Road. But a lot of people swear by the larger silicone lines. For your S here's the venturi delete and idle stabilizer hose to the manifold 944online.com - Air / Fuel System Find Parts For Your Porsche 944 And Get Your Car Back On The Road. 944online.com - Air / Fuel System Find Parts For Your Porsche 944 And Get Your Car Back On The Road. On another note, I also like going to 944online to recognize parts by pictures, but wish they showed parts numbers too...
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush http://stores.ebay.com/Techniker-Parts/ |
AFM #725
I'd check everywhere else for parts first though, 944online usually has ridiculously high prices.
Make sure you change the two ICV (idle control valve) lines.
the venturi function appears to be over engineering from Porsche. You can remove it and tidy up the very messy vacuum hoses under the hood. It has no effect on performance if you keep it or delete it. And apparently Porsche doesn't sell the venturi or the hoses anymore, just the delete kit...
I'd get the venturi delete (if this if for your S) and the vacuum hard lines from 944online (also as I didn't find them anywhere else). Not bad prices. The vacuum y and c joints i'd get from pelican, much cheaper.
Its for the non S. lol
2002 E46 BMW ///M3 (Daily) 1987 Porsche 944S (Project) 1985.5 Porsche 944 (Sold) |
