Converted 944 Guy
Question 944- What would you pay?
Would like to hear your thoughts on the value of a 944 I am looking at.
It's a 1986 944, original owner with less than 85,000 miles. Paint and interior are immaculate. Clutch, master & slave replaced at 70,000 and timing belt, water pump done at 60,000. Owner has all records.
The car had not been driven for a couple months. Owner tried to start the car, noticed no oil pressure. He had the car towed to the shop and the issue was corrected. No issue now.
I talked to the mechanic and he told the following: small coolant leak around water pump, small coolant leak at oil cooler. Rollers are a little noisy. Timing belt in good shape. Of course, while taking care of the water pump leak and rollers, the timing belt might as well be done. Other than that the car is in excellent condition.
What would you pay for a one owner, low mileage 86 with these issues?
I've never worked on a 944 before so I'd probably hire the work out. I've got a number in mind for the price. Curious to hear what you'd pay.
Old 10-11-2013, 04:27 PM
944tothefloor's Avatar
Immaculate interior and paint? All records? Knowing he had the car towed to a mechanic is a good sign that he's a responsible owner. $4000-$4500 sounds decent. Pics? Good luck!
Old 10-11-2013, 04:43 PM
Proprietoristicly Refined
John_AZ's Avatar
Sounds great!
This is what Hagerty Insurance says--category 2:
You will need to improve your mechanic skills. Shop rate starts at $100+- an hour.
NOW, if you can get it for about the price around $6000 (or less)--buy it!
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-11-2013, 04:45 PM
flash968's Avatar
first off 85k is NOT low miles. that's high mid miles. high starts at 90-100k.
given the age, i would expect that most of the suspension bushings are shot.
just as a reference, it doesn't matter as much about mileage as it does age on the belts, and anything else rubber.
regardless, failing proof of new rubber stuff, i'm thinking maybe as much as $2500, as you can expect to spend $3k changing it out.
Old 10-11-2013, 04:46 PM
John_AZ's Avatar
Adding to what flash968 posted.
Just a few more comments to consider or negotiate with.
Be prepared to replace the HG head gasket on the car if not done previously.
The HG is deteriorating. My '88 with 69K miles, uses a sip of coolant on a hard run and I am preparing to replace it this winter.
Shocks, struts, and motor mounts if not done will need to be replaced. $1000 for parts.
Does the PS power steering leak? $300 for parts and labor $500.
Tire age? Check for date of MFG. $500 and up with alignment.
But how can you pass up this car!! Maybe offer a little less?
GL
J_AZ
Old 10-11-2013, 04:56 PM
Converted 944 Guy
You're correct, I should put mileage in proper context. I've only seen a few 944's with less than 90K. I suspect you're right about bushings, but after speaking to the owner he seems to have kept up on recommended maintenance schedules. Although, I haven't had the chance to go through the maintenance records yet (car is about 200 miles from me).
Buying decision would be dependent upon a PPI and full disclosure.
Old 10-11-2013, 04:59 PM
John_AZ's Avatar
OK, good to hear.
Now, what price does the owner want?
J-AZ
Old 10-11-2013, 05:05 PM
AFM #725
Gawernator's Avatar
Around $4k, I sold my 83 for 4.3k that was in decent cosmetic shape and a nice interior, with solid mechanicals. This sounds like it needs some mechanical work but as you say immaculate cosmetics. A lot of interior parts and especially paint can get expensive so definitely worth it if you can get a good price and wrench a bit.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 10-11-2013, 05:08 PM
This
Old 10-11-2013, 05:11 PM
Converted 944 Guy
GL
J_AZ
Good info, thanks. I will check into the items you mentioned. Owner says power steering is sound, rack has been rebuilt.
For the right price I'd love to own it. Have to see the maintenance records to see what I am up against. Luckily, the mechanic is very reputable and he's been very open with me so far.
We'll see how it goes...
Old 10-11-2013, 05:14 PM
racer's Avatar
While the mileage notations are nice (service "x" at 80K miles), how many YEARS has it been since mileage "X". If its been 4-5 years since a service, it may be "time" for it to be done again. I hardly put 2500 miles a year on my car, so I tend to fight against time, vs miles, since a previous item needs replacement.
Not often taughted, but know that the fuel lines run right along the top of the engine. How old do you want your lines to be?
Pics would really help too.. Color combination.. Fuchs vs phone dials (or cookies), paint condition, how's the dash? seats? is the hatch delaminted (delaminating) ? Does the odometer and trip odometer actually work? all the electrical work? Any options of note?
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 10-11-2013, 05:22 PM
Converted 944 Guy
OK, good to hear.
J-AZ
Too much...lol.
Asking $8k. I'm thinking more like $4-4.5k.
Old 10-11-2013, 05:29 PM
tamathumper's Avatar
$8K?! Wait six months and buy it at under $4K...
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 10-11-2013, 05:33 PM
John_AZ's Avatar
Originally Posted by Jrboulder View Post
This
Jr, we are talking about a California car--maybe the Fresno area.
This car has no rust, it has not been in snow or flooded by rain in the east coast-N or S. Or baked in the AZ sun. Hand washed and garaged. Paint, upholstery and carpets are pristine.
Why buy a $2000 low mileage car and put $3 to $4K in appearance?
What does a paint job cost on a 912E?
John
Old 10-11-2013, 05:36 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Rubber stuff is the key to probable near future maintenance costs: Tire Age, engine front seals, belts, throttle body little seals (vacuum), suspension boots and bushings, rubber clutch, brake lines & fluid flush, water pump, and by the way, since you're in California, what's the status of a current smog test? Still ...$4.5k is about right. Good luck with the negotiations.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 10-11-2013, 05:41 PM
John_AZ's Avatar
Too much...lol.
~$4K never gonna happen!!
The recession is over and housing prices are up 20-25% ....
J_AZ
Old 10-11-2013, 05:43 PM
Yeah, the demand for these cars is really going up, so are prices.
Old 10-11-2013, 05:49 PM
Converted 944 Guy
Car has just over 20k miles since 1998. So, not driven much which probably means a lot of replacement parts.
3/98- 68,000
1/00- 72,888
2/02- 74,121
5/05- 76,312
3/07- 77,111
3/09- 78,809
4/11- 80,083
Old 10-11-2013, 05:55 PM
Converted 944 Guy
John
California car. I have only seen pictures. Mechanic told me the car is extra clean, one of the best he's seen in years. Same guy was extremely honest about the work it needs. He's highly recommended by several PCA members in the area, so I trust him and his opinion.
Old 10-11-2013, 06:04 PM
I'd agree that 4.5 to 5k is fair. I paid $3900 for my 924S with 68k original miles and in almost perfect condition five and a half years ago, and the values have evidently gone up a bit since then. Plus later 944's tend to go for a bit more than the 924S or early 944's.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928
Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944
Old 10-11-2013, 06:13 PM
