AFJuvat's Avatar
Ahhh Scheisse!!
Well, went out to the garage this morning (4:20AM EDT), and the 44 wouldn't start. Cranks great, getting good oil pressure, just no start.
I've been having a bit of a "hot start" problem lately (takes longer to start on a hot day with a warm engine).
I'm suspecting the DME relay or the fuel pump/check valve. Also will consider battery ground wire, it was looking a little ugly last time the car was on a lift. As I was dressed for work, and due to the time, I did not have a chance to pop the hood and actually look at anything.
Plugs, cap, rotor, wires, and fuel filter were done within the last 10k miles.
Turning out to be a great day so far...had to drive the **gaccck** Hyundai to work...
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 08-15-2002, 02:27 AM
Mine would do that occasionally. Check the magnetic pickup lines coming off the top of the clutch housing where they plug into the other wire. Cleaned both leads where they plug together. For some reason engine would start when cold (always) but occasionally would fail to start when hot.
Old 08-15-2002, 04:11 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Was it dark the last time you drove it?
Check and see if you're getting ignition pulse to your coil.
Of course:check batt. terminals and the ground you mentioned.
Could the check valve be pluged? they seem like such simple things...
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 08-15-2002, 05:49 AM
AFJuvat's Avatar
Fixed it, it was the DME relay.
AFJuvat
Old 08-15-2002, 01:53 PM
todwic's Avatar
$%^@%^!$#@*@^&!%#!!! DME relays
'86 951
Old 08-15-2002, 09:00 PM
Send a message via Yahoo to jykk04
whats a DME? and why does it delay?
83' 944 - Devil in a Blue Dress... (Durango Metalic Blue)
Old 08-15-2002, 11:12 PM
SoCal Driver's Avatar
Do you have the Haynes 944 manual? Or the CDR's with the PDF manuals?
Serious questions.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-15-2002, 11:28 PM
AFJuvat's Avatar
Actually I did check those too, I was somewhat surprised that there was some corrosion as I had just changed both sensors last september when I did my clutch.
Applied a little dielectric grease to the contacts so hopefully that won't happen again.
The DME relay itself was toast, I opened up the case and git that "fried electronic smell" right away.
AFJuvat
Old 08-16-2002, 06:35 AM
AFJuvat
You let out the Magic Smoke!
Old 08-16-2002, 10:07 AM
AFJuvat's Avatar
Is that what that was???!!!
Hell, it is gonna die for sure now....
AFJuvat
Old 08-16-2002, 10:11 AM
rbt944's Avatar
I have the same problem on my 84. Which number is the DME relay??
RBT.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 08-16-2002, 06:13 PM
AFJuvat's Avatar
DME/Fuel Pump is #2
AFJuvat
Old 08-18-2002, 10:03 AM
Somewhere I remember seeing a plastic four prong relay puller.
Anyone???
Old 08-18-2002, 10:50 AM
rbt944's Avatar
Thanks AFJuvat.
RBT.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 08-18-2002, 08:35 PM
