-   -   Speedometer not working (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/778668-speedometer-not-working.html)
PorscheNut924 10-27-2013 04:05 PM
I took the speedometer out of my 1984 944 and opened it up, glued the odometer gear in place, and spun the shaft to verify that it works.
But I put it back together and still no speed or odometer. The cable end isn't stripped, as far as I can tell.
I'm assuming it's the cable...is there a weak point to check first? Where is the other end of the cable? Maybe it's not hooked up.
Jrboulder 10-27-2013 05:03 PM
Look for the circlip holding the cable into the drivers front wheel bearing dust cover. That's what hold the cable to the rotating assembly
mattdavis11 10-28-2013 04:00 AM
What Jrboulder said, you don't necessarily need a circlip either, mine has been band aided with a twist tie for years. It is possible that the cable has busted.
PorscheNut924 10-29-2013 05:46 PM
It is the cable, I talked to the previous owner and he said it snapped up by the front wheel. Not sure if that means the cable or something else snapped.
