Speedometer not working
I took the speedometer out of my 1984 944 and opened it up, glued the odometer gear in place, and spun the shaft to verify that it works.
But I put it back together and still no speed or odometer. The cable end isn't stripped, as far as I can tell.
I'm assuming it's the cable...is there a weak point to check first? Where is the other end of the cable? Maybe it's not hooked up.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928
Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944
Old 10-27-2013, 05:05 PM
Look for the circlip holding the cable into the drivers front wheel bearing dust cover. That's what hold the cable to the rotating assembly
Old 10-27-2013, 06:03 PM
Just thinking out loud
mattdavis11's Avatar
What Jrboulder said, you don't necessarily need a circlip either, mine has been band aided with a twist tie for years. It is possible that the cable has busted.
91 FJ80
84 Ram Charger (now gone)
Old 10-28-2013, 05:00 AM
It is the cable, I talked to the previous owner and he said it snapped up by the front wheel. Not sure if that means the cable or something else snapped.
Old 10-29-2013, 06:46 PM
