Deposits on Pistons
So I removed the head, took off the valves, etc and sent the head in to be cleaned and such. Now, I am staring at my pistons that are covered in black deposits in a cresent shaped pattern.
Whats the best way to clean/remove these deposits?
Brian
Old 08-19-2002, 06:07 AM
SoCal Driver's Avatar
Wire brush on the end of a drill motor.
Shop vacuum the crud that comes loose. Don't let it get into the cooling jacket.
I usually drop the piston down a 1/4" or so from TDC to "fence in" the crud.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-19-2002, 06:49 AM
AFJuvat's Avatar
Many auto parts stores sell a decarbonizer. That couples with a brush usually helps
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 08-19-2002, 06:55 AM
I used a brush and gas to help get them clean.
Old 08-19-2002, 04:06 PM
