Send a message via Skype™ to massive
Missing gears 2, 4 and reverse
Near impossible to get 2, 4 or reverse gears, 1, 3 and 5 are okay though. Have checked linkage at gear stick end and all is fine. The gear stick moves backwards, forwards and side to side okay, but just doesn't seem to want to engage. So am thinking either the shifter mechanism on top of the transmission has gone bad or worse something internal in the transmission.
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 12-22-2013, 03:03 AM
You definatly need to check the linkage at transmission
Old 12-22-2013, 07:37 AM
West Central Ohio 45380
plyhammer's Avatar
Sounds like the bolt with the conical end at the linkage has slipped
Old 12-22-2013, 07:41 AM
UPDATE: As suspected the bolts on the short shift linkage had worked loose, not helped by the grease that had been over-applied to the rose joint. Cleaned everything up and used red thread lock on the bolts. All is good again.
Old 01-03-2014, 01:38 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
A shame you didn't use the opportunity to install one of Only944.com's short shifter since you were in there already. Still, it only takes about 1/2 hour to install it and you can't imagine what a joy it is to shift afterwards.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 01-03-2014, 06:06 PM
I already have another type of short shifter kit fitted, coincidently I took the precaution of ordering the only944.com one too. Received it the other day and it is far superior in build quality than the one I have attached at the moment.
Old 01-05-2014, 09:53 AM
