-   -   Need help with Cooling Sys. Problem (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/78852-need-help-cooling-sys-problem.html)
led 08-27-2002 04:46 PM
I was tightening the cooling system bleed screw and the metal elbow that connects the upper radiator hose to the cyl. head (pic) broke so now the water leaks out. What part # is that and where can I get it?
http://members.roadfly.org/l3d/my%20prob.jpg
BTW: it's a '86 944na
AFJuvat 08-27-2002 05:29 PM
You can check here on Pelican for some of them (gaskets etc) but most will have to either come from a parts car or the dealer.
944.104.315.04 - Housing
944.104.311.04 - Gasket
931.106.156.00 - Bleeding screw
N.013.830.7 - Sealing ring
AFJuvat
todwic 08-27-2002 07:37 PM
yer better off to go to a junkyard or Partsheaven.com for hard parts like that. Next time don't tighten it so !$%#$^%& tight, ya Animal!
todwic 08-27-2002 07:46 PM
nice looking motor, BTW
led 08-27-2002 08:08 PM
http://www.pelicanparts.com/support/...s/a_frusty.gif hehe I overtightened it because it kept leaking water, I suspect the PO replaced the bleed screw with a longer one or something. BTW, It never stopped leaking... also, that's not my car it's Mike S's over at rennlist, I really like the int. manifold!
todwic 08-27-2002 08:11 PM
There's a gasket that goes there. I lost mine and substituted a fibre gasket of appropriate size and works fine. There should be rubber material on the underside of you bolt, and a washer of resonable thickness.
divezic 08-28-2002 05:53 AM
I'd try either www.944ecology.com or partsheaven.com for those non-standard maintenance items. Also, if you have an auto salvage yard nearby, call them and see if they have any 944's on the lot.
I just checked Pelican's Ads and they have a few 944's being parted out. Try this... http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/
