led led is offline
led's Avatar
Exclamation Need help with Cooling Sys. Problem
I was tightening the cooling system bleed screw and the metal elbow that connects the upper radiator hose to the cyl. head (pic) broke so now the water leaks out. What part # is that and where can I get it?
BTW: it's a '86 944na
1.1 million words in the English Language and not one can describe the feeling. Porsche. There is no substitute.
'86 944na
Old 08-27-2002, 04:46 PM
AFJuvat's Avatar
You can check here on Pelican for some of them (gaskets etc) but most will have to either come from a parts car or the dealer.
944.104.315.04 - Housing
944.104.311.04 - Gasket
931.106.156.00 - Bleeding screw
N.013.830.7 - Sealing ring
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 08-27-2002, 05:29 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
yer better off to go to a junkyard or Partsheaven.com for hard parts like that. Next time don't tighten it so !$%#$^%& tight, ya Animal!
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 08-27-2002, 07:37 PM
todwic's Avatar
nice looking motor, BTW
'86 951
Old 08-27-2002, 07:46 PM
led led is offline
led's Avatar
hehe I overtightened it because it kept leaking water, I suspect the PO replaced the bleed screw with a longer one or something. BTW, It never stopped leaking... also, that's not my car it's Mike S's over at rennlist, I really like the int. manifold!
'86 944na
Old 08-27-2002, 08:08 PM
todwic's Avatar
There's a gasket that goes there. I lost mine and substituted a fibre gasket of appropriate size and works fine. There should be rubber material on the underside of you bolt, and a washer of resonable thickness.
'86 951
Old 08-27-2002, 08:11 PM
I'd try either www.944ecology.com or partsheaven.com for those non-standard maintenance items. Also, if you have an auto salvage yard nearby, call them and see if they have any 944's on the lot.
I just checked Pelican's Ads and they have a few 944's being parted out. Try this... http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/
-Dave-
1969 911/3.0l SC
Old 08-28-2002, 05:53 AM
