Ate caliper rebuild : rear spring clips
The shop manual says to not mix up the spring clips from the rear calipers. I seem to have done so. They have a subtle shape difference - one arm is straighter than the other.
Which arm goes on which side of the cylinder - or any other clues?
Old 01-13-2014, 05:43 PM
AFM #725
Gawernator's Avatar
Um..... I remember them being basically the same
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 01-13-2014, 11:26 PM
In the Fires of Hell.....
kdjones2000's Avatar
I just did my rears tonight, and yes the two arms of the springs are indeed different.
Did you mix up your L/R caliper parts, so you don't know which one goes with which cylinder?
From what I can tell, the more bent arm goes on the same side as the bleeder.
Don't forget the 20 degree rotation for the piston as well.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 01-15-2014, 09:19 PM
I mixed up the clips. The bleeders go up. The other pieces are evidently exchangeable.
Do you have an explanation?
87 944 NA
Old 01-16-2014, 05:42 AM
Ummm, I looked at my calipers?
Old 01-16-2014, 08:12 AM
