-   -   Single-piston caliper rebuild : vise (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/789503-single-piston-caliper-rebuild-vise.html)
Bukowski 12-30-2013 10:50 AM
How much grief will I save if I use (really buy - I don't have one) a vise for rebuilding the single-piston Ate calipers?
John_AZ 12-30-2013 11:13 AM
http://forums.pelicanparts.com/uploa...1388430274.jpg
or
http://forums.pelicanparts.com/uploa...1388430289.jpg
...under normal conditions.
I cannot think of a use for a vice when I rebuild calipers. Just make sure the piston is set correctly to the caliper/frame before you push it in. Read the directions and the pictures.
Bench Bleeding the brake MC ----yes.
J_AZ
Gawernator 12-30-2013 02:30 PM
What would you need a vice for
Slam 12-31-2013 06:14 AM
Holding the frame while you wire-wheel the crap out of it getting the rust off, get the piston out, dig out the old seal, press the slug back in, fight with the sliding part, and on and on.
Not my only vice...er, vise.
CHICKS 12-31-2013 06:27 AM
A vise is a good tool to have in general, so why not? If you want to get fancy, look for an old American made Wilton. Anyways, I have a China made Bessey that works just fine. Check out flea markets, garage sales, pawn stores, Craigslist, etc... The Garage Journal
Bukowski 01-07-2014 01:11 PM
J_AZ
think I can get away with using some C-clamps?
gtroth 01-07-2014 06:23 PM
You should have a vise.
For your reading pleasure:
Everything you need to know about bench vises... - The Garage Journal Board
The VISES of Garage Journal - The Garage Journal Board
Bukowski 01-07-2014 08:55 PM
gtroth, I read that last week! It's great!
Notwithstanding, I'll probably get the Sears vise.
UPDATE : got the vise.
