Single-piston caliper rebuild : vise
How much grief will I save if I use (really buy - I don't have one) a vise for rebuilding the single-piston Ate calipers?
Old 12-30-2013, 10:50 AM
Proprietoristicly Refined
John_AZ's Avatar
or
...under normal conditions.
I cannot think of a use for a vice when I rebuild calipers. Just make sure the piston is set correctly to the caliper/frame before you push it in. Read the directions and the pictures.
Bench Bleeding the brake MC ----yes.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 12-30-2013, 11:13 AM
AFM #725
Gawernator's Avatar
What would you need a vice for
Old 12-30-2013, 02:30 PM
Back from Beyond
Holding the frame while you wire-wheel the crap out of it getting the rust off, get the piston out, dig out the old seal, press the slug back in, fight with the sliding part, and on and on.
Not my only vice...er, vise.
Old 12-31-2013, 06:14 AM
Andrew Gawers' Dad
CHICKS's Avatar
A vise is a good tool to have in general, so why not? If you want to get fancy, look for an old American made Wilton. Anyways, I have a China made Bessey that works just fine. Check out flea markets, garage sales, pawn stores, Craigslist, etc... The Garage Journal
Old 12-31-2013, 06:27 AM
J_AZ
think I can get away with using some C-clamps?
87 944 NA
Old 01-07-2014, 01:11 PM
gtroth's Avatar
You should have a vise.
For your reading pleasure:
Everything you need to know about bench vises... - The Garage Journal Board
The VISES of Garage Journal - The Garage Journal Board
1995 993C4 guards red
1988 944S alpine white
Old 01-07-2014, 06:23 PM
gtroth, I read that last week! It's great!
Notwithstanding, I'll probably get the Sears vise.
UPDATE : got the vise.
Old 01-07-2014, 08:55 PM
