Caliper rebuild : L/R matching
When rebuilding calipers - should it matter which floating frames and mounts go with a particular cylinder?
For instance they are completely disassembled and organized by front/rear parts, and left/right cylinders. However, the frames and mounts appear symmetric and exhibit negligible measured differences. Note that I wrote "should". This means I know it *could*, depending on what happened to them. I am asking for differences in design. I suppose the same goes for pistons. UPDATE: Shop manual p. 47-2 " spring guide, rear wheel brake caliper: don't mix up left and right spring guides" - I didn't. Pistons seem tighter in one cylinder but not the other. Last edited by Bukowski; 01-11-2014 at 12:11 PM.. |
