Yep, I've done that!
5th swap
Does anybody with a 944 Turbo want a taller 5th gear? I have one but I need to trade for your shorter 5th. I am willing to do the swap if you deliver your gearbox to me in Utah.
Lets talk!
71' 911 Fully restored Tarmac Rally Long Hood RSR 03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine! 00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast! 86' 944 SPEC Car 'In Process' 2013 Debut |
Bump...
P.S. I will also sell a tall 5th gearset if interested...
can you rebuild a gearbox while doing the gear swap?
Swaping the 5th is a minimally invasive process that is vastly different than an overhaul. I am also not able to properly set up the ring and pinion as I do not have the required tools.
I have done the overhaul for my own use but it required a lot of time and regular inspections after run in. Not something I would do for anybody else.
