1990 s2 exterior lights are off on passenger side
Help! Any idea what’s going on?
my passenger side side markers, tail light are not working. Driver side turns on but passenger side is off. fuse 41 keeps blowing out. I took out both side markers and tail lights and made sure all terminals are connected and bulbs are good. I only see 2 grounds - one at tail light and one in the front driver side. Both are cleaned. Also, my driver side fog light is off and under hood light is off. |
Look at the wiring and sockets for something causing the fuse to blow like a cracked socket or frayed wire insulation.
Thanks. Nothing so far. I cleaned all the light connectors for fog, signal and side marker lights. Wires look good.
There is no brake light when I step on the brake pedal. Passenger lights are still off. |
When the brake pedal switch fail, does it affect tail light when I turn on the head light? My left tail light is on with parking light.
Could it be the head light switch?
All corners of the signal and tail light work with hazard light on Tail light does light up under braking now |
If the key is off and turn signal lever is engaged the parking lights on that side should light, too.
Check the loom as it runs across the spare tire well.
One parking light is not getting power. Using a circuit tracer, the harness appears to hv connectivity back to fuse box. Any idea why power is not going to that light?
