-   -   Top end rebuild help (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/795459-top-end-rebuild-help.html)
PHillary 02-22-2014 07:01 PM
Here are some pics of front bumper test fit, will be installing it tomorrow.
http://forums.pelicanparts.com/uploa...1393124237.jpg
http://forums.pelicanparts.com/uploa...1393124251.jpg
http://forums.pelicanparts.com/uploa...1393124302.jpg
http://forums.pelicanparts.com/uploa...1393124377.jpg
http://forums.pelicanparts.com/uploa...1393124405.jpg
9FF 02-22-2014 07:56 PM
Florida: working on your car year round wearing just a t-shirt, shorts & flip flops ;)
PHillary 02-22-2014 10:53 PM
Can I PM anyone to pay them for pages 15-101 and 102 out of the Engine 1A Workshop Manual?
jeffrsmith 02-23-2014 10:50 AM
PHillary - I have sent you an email through the forum.
PHillary 02-23-2014 03:25 PM
Got some pics of the final install , not perfect but I'm not perfect.
http://forums.pelicanparts.com/uploa...1393197919.jpg
http://forums.pelicanparts.com/uploa...1393197943.jpg
PHillary 02-23-2014 05:04 PM
Next weekend the spoiler!
CHICKS 02-23-2014 06:29 PM
In 1a (16valves) 15-101 is "tools for adjusting camshaft settings (16-valve engines). Page 15-102 is "checking and adjusting camshaft settings". I took a pic, I'll post em tomorrow.
Jrboulder 02-23-2014 06:36 PM
https://scontent-b-ord.xx.fbcdn.net/...2d&oe=530D2AD6
https://scontent-b-ord.xx.fbcdn.net/...62&oe=530CAF75
CHICKS 02-23-2014 06:45 PM
There it is. Thanks Jackson.
PHillary 02-23-2014 07:12 PM
Thanks Jrboulder, you are the man!
Jrboulder 02-23-2014 07:33 PM
CHICKS took the pictures and sent them to me to post for him. It's all him.
PHillary 02-23-2014 07:44 PM
Well then "CHICKS", I owe you a big thank you too. So here it is: Thaaank You!
CHICKS 02-23-2014 07:49 PM
No problem. Good luck!
jeffrsmith 02-24-2014 02:55 AM
As a precaution, before you start to align the cams be sure to rotate the crank approx 45 degrees to ensure there will be no valve to piston contact. Once you are finished installing the cam chain and have the cams aligned, turn the crank back to TDC, put the crank lock on to hold at TDC and install your timing belt.
PHillary 02-24-2014 05:36 AM
Thanks, Will do.
PHillary 03-03-2014 02:08 PM
Here's some more photos....
http://forums.pelicanparts.com/uploa...1393884272.jpg
http://forums.pelicanparts.com/uploa...1393884327.jpg
http://forums.pelicanparts.com/uploa...1393884362.jpg
http://forums.pelicanparts.com/uploa...1393884383.jpg
Decided to play it safe and take it mechanic, they have a good Rep and willing to help me put all the pieces back together.
jeffrsmith 03-03-2014 03:28 PM
At least now you have the manual pages to provide to the mechanic so he has something to go by, hopefully he will be able to complete the job in a timely manner!!
HondaDustR 03-03-2014 05:14 PM
Oil cooler seals are an exercise in frustration with the exhaust headers in place, but so is removing Y-pipe bolts welded to the headers with rust.
At least on the 8V heads, the exhaust valve guides are pretty worn after 150K. Depending on the mileage of the head, it may or may not be a big deal to leave them be. The smaller valves may extend the service life of the guides over the 8V head. Worn guides will accelerate wear on the valve seats leading to lower compression and additional work down the road.
I would say at minimum, the valves should be lapped in and valve stem seals replaced. Pretty easy to do if you've already come all this way. Now then there's hand porting the head and intake while you wait for machine work to finish up, but that's another story...
PHillary 03-06-2014 05:44 PM
Added my Momo wheel and Rennline pedal set today. Wanted to get it ready for the shop tomorrow.
http://forums.pelicanparts.com/uploa...1394156549.jpg
http://forums.pelicanparts.com/uploa...1394156656.jpg
