Send a message via Yahoo to jykk04
Replacing my Rear wheel bearings..HELP!!!
I'm replacing my Rear wheel bearings.. and ANY suggestion would be very helpful.. LIKE HOW TO DO IT... I'm new at working on my car and i'm loving it but i'm not good at it.. i took the all the parts out now i need help putting the new bearings in.... stuff that i bought:
http://www.pelicanparts.com/cgi-bin/smart/oboe/track.pl?command=lookup&Order_Id=1030460708-840
that and of course bearing greese..
83' 944 - Devil in a Blue Dress... (Durango Metalic Blue)
Old 09-04-2002, 05:59 PM
Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
You also need to get the outer seals. You can get them at your local auto parts store.
'86 944, 5 Speed (Daily Driver)
Old 09-04-2002, 06:23 PM
you freaked me out. so i went to the site, and it comes with outter and inner seal thank god.. hehe.. any suggetion how to do it.. and things not to forget??
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_suspen_pg8.htm#item24
Old 09-04-2002, 06:32 PM
MixMasterK's Avatar
Double check your order and make sure you have 4 seals there.
As far as how to do it:
1. Remove the CV shaft from the rear spindle.
2. Remove the tire.
From this point I'm not sure as I have only done the ones on my 924 and not my 944. However I will take a stab at what I think you will see and need to remove (assuming that this has disk brakes in rear). Any one else on here sees something wrong, please jump in.
3. Remove the nut from the shaft running through the hub.
4. Pull out the shaft from the inboard side of the hub. you may need to coax it out with a rubber mallet. Clean the shaft of old grease and any minor rust. Be careful not to gouge the surface where the seals and bearings ride.
5. Remove old seals. Note which is inboard and outboard.
6. Remove O-ring.
7. Remove bearings. Note which one is inboard and outboard.
8. Remove spacer tube inside and clean out old bearing grease.
9. Repack hub liberally with new bearing grease.
10. Intstall new parts in reverse of removal. Be sure to pack the bearings with grease before installing them. Once you have one of the bearings installed, pack the hub as full of the bearing grease as possible. Then install the other bearing.
11. Look up torque specs for the hub shaft nut and also the allen bolts on the CV shaft.
The whole process is rather straight forward once you get into it. Do one side at a time. Once you do one side the other will go much faster. Hope this helps. Have fun.
Old 09-04-2002, 06:50 PM
hey thanks, and yes i did orded 4 of them.. i'll post up how it went after i'm done.. thanks for the idea..
Old 09-04-2002, 06:55 PM
MixMasterK's Avatar
The bearing races may also need some coaxing to get them out of the hubs. Try not to score the inner hub surfaces and be sure to install the new bearings straight.
Old 09-04-2002, 07:04 PM
If you don't have an impact, you'll need the help of about 8' of 1 1/2 " pipe to get the spindle nuts loose.
drew1
Old 09-04-2002, 10:42 PM
AFJuvat's Avatar
Get the bearings packed.
Put them in a freezer for a few hours - it will shrink them slightly and make them slightly easier to install.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 09-05-2002, 05:41 AM
