Component Weights (list)
Weighed some of the components I've removed, so I'd be great to compile a list with all their weights. For those of us that are seeking to lighten the vehicle, this could prove useful.
I'll start. (11 lbs) late NA 6 blade radiator fans + housing (6 lbs) alternator/ac bracket (17 lbs) late alternator (4 lbs) rear wiper motor and arm (19 lbs) upper rear seat (1.5 lbs) hatch release motor |
(155 lbs) Andrew - Driver
Great idea.
Recent NA swap.
Cast Iron exhaust headers ~ 20 pounds OEM "tube" type headers ~10 pounds |
Here's a good source for wheel weights: Porsche Rims Wheel Weight | Measurespeed
Not that I am aware of ????
Both are factory. Fit is identical. All NA. The light weight tube headers were OEM on my '87, I replaced with cast iron. http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/798455-na-tube-exhaust-manifold-cracks.html J_AZ |
interesting, thanks
i wonder what the difference is between that tube type and the one on the 968? they look identical in the PET. part numbers are really close too. in 10 years i've only heard of one 968 header cracking. why would they crack in the 944 but not in the 968?
Henry, aka H.F.944,
Nice! Bookmarked. J_AZ |
The sound deadening under the rear hatch carpet: ~10lbs?
20lbs if your hatch leaks!
lolol
Anyone have a weight difference between the US vs Euro bumpers?
Hmmmm... chunky aluminum vs fiberglass. (or is it plastic?) |
they are a type of reinforced plastic. they are very light, but are quite strong. Your sunroof skin is made of similar stuff. I've had a few low impact hits on mine including a tire wall and a possum and it's done no damage except to the paint. I replaced my front bumper with an AIR 924 carrera GTS reproduction.
I forget how heavy it is but i can hold it outright in one hand with a straight arm comfortably for a good few minutes. there is an in between aluminium bumper but Im unsure of the option code for it or why it was deemed necessary. to me its sticks out as very different from a normal RoW/euro front bumper and is similar to US bumpers. this car lives a few hours south of me. http://iforce.co.nz/i/qbo3et3f.nki.jpg It sticks out more like a US bumper and it has much more pronounced bumperettes. I think they may be metal like US ones, not rubber like RoW ones. The lighting arrangement is identical to RoW bumpers but they are mounted cleanly to the bumper. On RoW bumpers they have a plastic frame that screws in over the top and the rubber bumperettes are screwed into the frames. compare it to my cars old bumper on a similar angle http://iforce.co.nz/i/hukfkf03.c4p.jpg |
Aha, I see.
That bumper on the maroon car looks identical to the US/Canada ones. Minus the bumperette and driving light. I don't like how ridiculously square our bumpers are. The ROW ones fit much better since they taper as the go forward, and there's a cutout that matches the valance. Our massive bumperettes are also rubber. |
apparently the saudi-arabia-spec 944s had a euro-style bumper but it was made from aluminum. i've only ever seen 2 such cars in the US and both owners said the same thing.
The tubular 85 - 86 headers will crack. Replaced on my 85.5 with a cast header as cost of newer header was exorbitant. I occasionally wonder if the flow and heat transfer characteristics of the tubular is any better than cast, but the car is a beater (automatic dd) anyway. (tubular sounded better)
For posterity..
A complete rear hatch (all glass, with frame and rubber wing and hinges) is 52 lbs. ...not 80 as is claimed on the "lighter parts" company's website. A bare early dashboard weighs less than 7 lbs. |
yup - gotta be wary about that stuff. it's like one company that lists a carbon fiber hood for the 968. sure, it's got carbon fiber, but it's lain over fiberglass. gotta look deeper into some of that stuff.
968 Mirrors are significantly lighter
http://www.pic-upload.de/view-25601409/Weight.png.htmlAnother option to save some weight.
968 Mirrors are significantly lighter. My car is now another 3.7lbs (1.700g) lighter + improved center of gravity.;) http://www11.pic-upload.de/19.12.14/hsngy5ldtdyq.png |
