AC Problem 944 from 84'
Hi.
I am install AC in my Porsche 944 Early form 84'.
I have a question. What is it this of red circle?
Thanks.
Old 03-18-2014, 04:45 AM
Proprietoristicly Refined
John_AZ's Avatar
The PET # 928 573 096 03 identifies it as a "A/C valve" sold on Pelican:
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Later cars only have the lower "(freon) AC pressure switch" to the right in the photo.
Pelican Parts - Product Information: 959-613-137-00-M212
I tried to trace the wires in the WSM early electrical but did not find it listed or where the wires attached went.
Maybe just a dash lamp showing AC ON/OFF.
An AC pro on the board will know.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-18-2014, 11:50 AM
ok. Thanks for the information.
I think it may be high-pressure safety switch.
This is the electric wire diagram AC of 944 Early 84' like mine.
Why not this high-pressure safety switch appears?
And I do not know how to connect electric circuit.
Old 03-18-2014, 12:59 PM
Just thinking out loud
mattdavis11's Avatar
That isn't OEM to an 83 car, might be for an 84 though, however, that's where the high side pressure port is. My guess is it's a high pressure cut out switch, but that switch doesn't need to be there (and you don't want it b/c you can't read the high side otherwise) if the pressure switch that John mentioned works properly.
91 FJ80
84 Ram Charger (now gone)
Old 03-18-2014, 05:00 PM
