-   -   Problem Installing headers (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/804177-problem-installing-headers.html)
GHEN 04-01-2014 05:13 PM
Hi all,
So I have these Bursch headers with the long tube. http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=PEL-BUR-7914&catalog_description=&Bursch%2520Header%252C%2 520%2539%2532%2534S%2520%2528%2531%2539%2538%2537% 252D%2538%2538%2529%252C%2520%2539%2534%2534%2520% 2528%2531%2539%2538%2533%252D%2538%2539%252C%2520n ot%2520for%2520S%252C%2520S%2532%252C%2520or%2520T urbo%2529
They are ready to go in but there is no way I have enough room to put these in. It seems I am going to have to lift the car WAY higher than I am able to.
Anything I am missing? If not, any relatively safe ways to get my car high enough off the ground?
Thanks in advance.
GHEN
John_AZ 04-01-2014 05:36 PM
These?
http://forums.pelicanparts.com/uploa...1396398969.jpg
flash968 04-01-2014 06:17 PM
i had a similar 4 to 1 for a while. it indeed had to go up just about as high as my tall jackstands went.
Jrboulder 04-01-2014 06:26 PM
It's just as fun coming out
GHEN 04-01-2014 09:16 PM
Originally Posted by John_AZ (Post 7993375)
Those are the ones.
veleno 04-02-2014 02:08 AM
Too bad that doesn't fit my '90 S2!
petrolhead611 04-02-2014 03:18 AM
Think you will need to get the front of the car to a similar height as if removing engine, ie 25 or so inches from bottom of front valance to ground. It ain't too easy to do either-I had to borrow a friends highlift longreach jack and even then had to put a 3"wooden block between the saddle and the cross member.
