-   -   Got my headers in...mostly (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/804980-got-my-headers-mostly.html)
GHEN 04-06-2014 02:34 PM
DO NOT BUY FULL LENGTH HEADERS UNLESS YOU HAVE A LIFT!!
It was a ***** to get them in and there is still one snarl I have to work out...hopefully minor, too wrecked to go into detail right now but there are pictures of the makeshift "hi lift" and the car here:
https://plus.google.com/116352624872368148575/posts/ApPmqz6N8Bn
More pictures to follow.
GHEN
John_AZ 04-06-2014 02:51 PM
Nice!
I thought that was a finger in the glass..
http://forums.pelicanparts.com/uploa...1396821087.jpg
GHEN 04-06-2014 06:08 PM
Originally Posted by John_AZ (Post 8001101)
Nice!
Ha :-) No Chicago is a tough town but luckily not that tough.
One of the studs gave (is giving) me a lot of trouble. These are the engine studs that take an allen key made by Rennbay & sold here on Pelican Parts. Really nice to work with for 7/8 of them. One of the studs went in not very far and stuck! Tried to get it out with the allen ey and it stripped. Tried to double nut it out and it wouldn't come?!? I got those nuts as tight against each other as I could and they still turned without the stud. It was very frustrating.
Finally I left it. I am going to buy a stud extractor attachment for my ratchet and get it out but it is certainly a mystery...it is as if there was epoxy in the blind hole (which I know there wasn't).
Any thoughts are appreciated.
<!-- Place this tag in your head or just before your close body tag. -->
<script type="text/javascript" src="https://apis.google.com/js/plusone.js"></script>
<!-- Place this tag where you want the widget to render. -->
<div class="g-post" data-href="https://plus.google.com/116352624872368148575/posts/6M1agxQVPkW"></div>
GHEN
veleno 04-07-2014 05:42 AM
With the extra heat produced from the header I'd consider changing those fuel lines.
John_AZ 04-07-2014 05:52 AM
Might try heating with propane torch or welding a nut to the stud???
GL
J_AZ
CHICKS 04-07-2014 05:56 AM
Agreed, they need to be done asap. Unless you have an agreed value insurance policy then let that fucher burn. You'll come outta it with a 951.... ;)
Products for fuel lines.
GHEN 04-07-2014 06:28 AM
Fuel lines are on the list, however I did have the header coated at Jet Hot so that should handle some of that heat, no?
GHEN
GHEN 04-07-2014 07:29 AM
...just ordered a fuel line kit...better to be safe than sorry. Thanks guys.
GHEN
CHICKS 04-07-2014 07:38 AM
GHEN
Nice. They're easy to do too. SmileWavy
