What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Horn will not work!!
My horn won't work. I replaced the relay but it was for a late car. Do I need a relay specifically for my early (83)?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 04-11-2014, 03:24 PM
Custom User Title
mikepellegrini's Avatar
How about the engine compartment grounds?
Old 04-11-2014, 04:26 PM
Something I must check as I replaced the engine recently..Horns have not worked since then... Also, I noted in PET that the relay looks like it has a fuse in the front of it? whats up with that?
3-924's (Sold)
1967-912 (Traded)
Old 04-11-2014, 07:04 PM
Just thinking out loud
mattdavis11's Avatar
You need to ground the rack to the cross member. Once you get under the car, you will probably see the dangling ground wire you forgot to connect or broke in the process of the engine replacement.
91 FJ80
84 Ram Charger (now gone)
Old 04-12-2014, 06:03 AM
Misunderstood User
My first thought is check the horns. I have replaced mine over the years.
Check for the power, ground wire and the switch. The relay be my last choice as your horns were working prior to your engine work.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 04-12-2014, 09:06 AM
