-   -   Turn Signal won't blink (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/806535-turn-signal-wont-blink.html)
kleinfall 04-16-2014 06:03 AM
For all you 944 gurus out there - my front passenger turn signal lights up when running lights are on - but won't flash when turn signal engaged. Last year at inspection it didn't work - but while we were standing there talking about it - it started flashing so he passed it. Here lately not so lucky and inspection is almost due. Would this be a relay issue - since bulb works - just doesn't flash. Is the bulb a single filament or dual filament? The back passenger turn signal works fine. Thought I would run it by everyone first instead of trial and error.
fiat22turbo 04-16-2014 06:07 AM
Front is dual filament and it could be a bad contact within the housing or the flasher itself has an issue.
tamathumper 04-16-2014 10:16 AM
You're probably just low on blinker fluid... or I suppose those particular contacts could be dirty in the front housing like fiat22turbo said. But I'd check the blinker fluid just to be sure. ;)
sausagehacker 04-16-2014 10:51 AM
When you turn on the hazards does it flash?
Grandad#3 04-16-2014 11:37 AM
Hello, the Indicator Flasher Relay "G4" is either bad or you have a bad bulb. Check the wiring around the bulb housing for breaks.
Cheers,
Larry
kleinfall 04-16-2014 05:00 PM
Thanks for help. Popped off lens pulled out bulb had some oxidation on contacts. Also one contact behind bulb seemed too far back. Pulled it forward a little and put in new bulb. All good now
guru944 04-17-2014 10:22 AM
Nice.....
Later.
