Turn Signal won't blink
For all you 944 gurus out there - my front passenger turn signal lights up when running lights are on - but won't flash when turn signal engaged. Last year at inspection it didn't work - but while we were standing there talking about it - it started flashing so he passed it. Here lately not so lucky and inspection is almost due. Would this be a relay issue - since bulb works - just doesn't flash. Is the bulb a single filament or dual filament? The back passenger turn signal works fine. Thought I would run it by everyone first instead of trial and error.
Old 04-16-2014, 06:03 AM
fiat22turbo's Avatar
Front is dual filament and it could be a bad contact within the housing or the flasher itself has an issue.
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 04-16-2014, 06:07 AM
tamathumper's Avatar
You're probably just low on blinker fluid... or I suppose those particular contacts could be dirty in the front housing like fiat22turbo said. But I'd check the blinker fluid just to be sure.
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 04-16-2014, 10:16 AM
plays with toy cars
sausagehacker's Avatar
When you turn on the hazards does it flash?
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 04-16-2014, 10:51 AM
Hello, the Indicator Flasher Relay "G4" is either bad or you have a bad bulb. Check the wiring around the bulb housing for breaks.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 04-16-2014, 11:37 AM
Thanks for help. Popped off lens pulled out bulb had some oxidation on contacts. Also one contact behind bulb seemed too far back. Pulled it forward a little and put in new bulb. All good now
Old 04-16-2014, 05:00 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Nice.....
Later.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 04-17-2014, 10:22 AM
