Window won't go up. Or down. Or anything.
Hooked a battery up to my torn apart project car just to test some interior stuff. Began putting down drivers side window half way and thought "f*ck, what if it doesn't go up"... And whata ya know, it doesn't go up. When pushing the button to go up, or down, it now does nothing now. It only worked that first time and that's it. What could be the problem and how do I get this window up haha. Thanks.
Check fuse number 8 in auxiliary panel.16 amp.
Proprietoristicly Refined
1. Just swap the R & L door switches.
2. Squirt inside the switch with cleaner-do not pull apart 3. Pull the top of the switch off and pray you do not loose the springs or contacts in correct order. Clean and assemble. 4. Buy used switches on web and cross fingers the seller tells the truth. 5. Buy aftermarket switches cheap like URO and maybe get a couple of years use. 6. Keep the windows closed. J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Thread Tools | |
Rate This Thread | |
