-   -   What part needs replacing? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/807288-what-part-needs-replacing.html)
944s2cabriolet 04-20-2014 11:02 AM
Not sure what part in the assembly needs replacing? I need to replace something for a safety on the suspension. I can't figure it out with out disassembling. I only have a hoist for a few days and would like to figure out what I need before I start. The images show the problem, the gap between the rubber and the metal. Any help will be greatly appreciated. I have a 1990 944 S2. Thanks in advance.
http://forums.pelicanparts.com/uploa...1398016298.jpghttp://forums.pelicanparts.com/uploa...1398016197.jpg
944 Ecology 04-20-2014 01:31 PM
You don't need to replace anything. That gap is normal on the 87 and newer cars.
guru944 04-20-2014 04:14 PM
Upper strut mount spherical bearing failure
944S2Cabriolet:
How many miles does the S2 have?
The angle and offset of the Upper Mount Hat seems to be "Offset" for too much. The distance should be 1 to 4mm at best and even all around. Suspect upper strut mount spherical bearing failure. It should not have any play or make noise when vehicle is driven.
PS: Recommend disconnect cruse control throttle cable from the solenoid. These sometimes get stuck on their own. Safety!
Later.
http://forums.pelicanparts.com/uploa...1398035643.jpg
944s2cabriolet 04-20-2014 08:07 PM
When I jack the car up the gap between the rubber and the metal gets smaller. This problem is on both sides. I've added two pictures of before and when I had the car jacked up. The gap gets smaller when the tire comes off the ground.
While on the garage floor:
http://forums.pelicanparts.com/uploa...1398048439.jpg
While Jacked up:
http://forums.pelicanparts.com/uploa...1398048528.jpg
944s2cabriolet 04-20-2014 08:17 PM
Guru944:
The Car has 92,000 miles on it. I use the cruise control sometimes on the highway. Is their some maintenance I could do to it?
