What part needs replacing?
Not sure what part in the assembly needs replacing? I need to replace something for a safety on the suspension. I can't figure it out with out disassembling. I only have a hoist for a few days and would like to figure out what I need before I start. The images show the problem, the gap between the rubber and the metal. Any help will be greatly appreciated. I have a 1990 944 S2. Thanks in advance.
Old 04-20-2014, 11:02 AM
You don't need to replace anything. That gap is normal on the 87 and newer cars.
Good luck, George Beuselinck
Old 04-20-2014, 01:31 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Thumbs up Upper strut mount spherical bearing failure
944S2Cabriolet:
How many miles does the S2 have?
The angle and offset of the Upper Mount Hat seems to be "Offset" for too much. The distance should be 1 to 4mm at best and even all around. Suspect upper strut mount spherical bearing failure. It should not have any play or make noise when vehicle is driven.
PS: Recommend disconnect cruse control throttle cable from the solenoid. These sometimes get stuck on their own. Safety!
Later.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 04-20-2014, 04:14 PM
Porsche Crest
When I jack the car up the gap between the rubber and the metal gets smaller. This problem is on both sides. I've added two pictures of before and when I had the car jacked up. The gap gets smaller when the tire comes off the ground.
While on the garage floor:
While Jacked up:
Old 04-20-2014, 08:07 PM
Guru944:
The Car has 92,000 miles on it. I use the cruise control sometimes on the highway. Is their some maintenance I could do to it?
Old 04-20-2014, 08:17 PM
Tags
944 s2 suspension
