-   -   Fuen Gauge problem after cluster replacement. HELP (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/809754-fuen-gauge-problem-after-cluster-replacement-help.html)
onedroppr 05-05-2014 08:26 PM
Hi,
Today I replaced my 1987 944 NA original instrument cluster, with a nicer one that I bought few months ago to a board member.
All gauges are working properly. Old fuel gauge was reading 1/4 tank. Then when I replaced the cluster fuel gauge started to read 3/4 tank. I drove few minutes and take some hard turns to see if the sender was out of place but gauge stayed rock solid at 3/4.
I proceed to add 20 liters of gas, and now gauge is reading steady 4/4. I drove few miles to see if gauge went down, but nothing happens.
There's any chance gauge is out of calibration? Any help is welcome.
onedroppr 05-06-2014 07:40 PM
Sender was reading about 20.1 ohms, that I supposed is about 2/4 tank, and needle was at 4/4.
ASAP944 05-14-2014 05:00 PM
Use your finger to make sure the needle will move to 4/4. I just replaced my cluster and the fuel needle would only manually move to just above 2/4. I took off the needle and adjusted so that it moves from 0/4 to 4/4. I filled up the tank and it now reads 4/4.
