Fuen Gauge problem after cluster replacement. HELP
Hi,
Today I replaced my 1987 944 NA original instrument cluster, with a nicer one that I bought few months ago to a board member.
All gauges are working properly. Old fuel gauge was reading 1/4 tank. Then when I replaced the cluster fuel gauge started to read 3/4 tank. I drove few minutes and take some hard turns to see if the sender was out of place but gauge stayed rock solid at 3/4.
I proceed to add 20 liters of gas, and now gauge is reading steady 4/4. I drove few miles to see if gauge went down, but nothing happens.
There's any chance gauge is out of calibration? Any help is welcome.
Old 05-05-2014, 09:26 PM
Sender was reading about 20.1 ohms, that I supposed is about 2/4 tank, and needle was at 4/4.
Old 05-06-2014, 08:40 PM
Use your finger to make sure the needle will move to 4/4. I just replaced my cluster and the fuel needle would only manually move to just above 2/4. I took off the needle and adjusted so that it moves from 0/4 to 4/4. I filled up the tank and it now reads 4/4.
Old 05-14-2014, 06:00 PM
