Electrical connection
When I put the motor back in last weekend, I have one loose connector that I can't seem to figure out where it goes to and where the other half is. Can someone look at the picture and let me know. It is right by the Oxygen sensor.
Thanks,
Dustin
Current Porsches
'10 Panamera 4S, '66 912, '90 928 GT, '83 944 Track Car
Past Porsches
'06 997 C4S, '68 912, '99 996 C4, '97 Boxster
Old 05-11-2014, 06:45 AM
That looks extremely similar to the quick connect on my battery tender, I'm not by my car right now to say for sure if it's 100% like that or if there's another connection that uses that, just a thought though
Old 05-11-2014, 08:25 AM
Patrick
pfarah's Avatar
Are you using the single wire O2 sensor (outside California)? If so, I think that connector is for the CA sensor, the wiring harness will contain both O2 connections. Disregard that one unless I'm totally wrong however; I have the same unused connector on my 84.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 05-11-2014, 04:45 PM
nightheart's Avatar
As above. thats the heated connector to connect a 3 wire O2 sensor, which where required when originally sold in California. The rest of the US used the non-heated 1 wire sensor. I'd assume many (all?) cars came with the 3 wires on the harness, whether the heated or non-heated sensor was used.
This was probably posted from my phone, so please excuse any typos.
Old 05-11-2014, 05:10 PM
Ok, great. Must have been that way and I forgot when I disconnected everything.
Current Porsches
Past Porsches
Old 05-12-2014, 07:43 AM
