SeaSkip 944 (guest)
Guest
Posts: n/a
I have a 87 944NA with 127 K miles on it the oil pressure was reading in the normal range 4-5 bar at operating pressure. Now afer my 3000 mile oil change its reading 2-3 barit goes up when the rpm increases but not much, at idle it is 0. I have taken out the oilpress relief value is there any what to do a test on the valve out side of the car..If it need a new valve fine... but I hate to spend money on it if the old one still works. any suggestions?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Parts - Comparison of Available Shipping Options
Old 02-28-2011, 01:03 AM
Author of "101 Projects"
Wayne 962's Avatar
Did you happen to change the viscosity or brand of oil to a different one? If you use a lighter weight oil, then you will find that you have lower oil pressures, which is typically okay. I don't have the spec on this valve handy, so unfortunately, I'm not sure what it should release at. I will copy this question to the forums to see if anyone has this spec.
- Wayne
Hi Seaskip, as Wayne mentioned about the oil weight, use oil with 15W/50 weight or higher.
Since you already had the oil press relief valve, test the plunger for free movement. Use a wooden dowel and press on the plunger through the hole in the front, and see if it moves in and out freely. You might be lucky it was just a small debris got caught preventing the plunger to close all the way.
Before you put it back, make sure you replace the two o-rings, one external and the other internal.
Good luck.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 02-28-2011, 03:02 AM
Proprietoristicly Refined
John_AZ's Avatar
Take the above advice.
Pelican has the OPRV -oil pressure relief valve- in the parts department. $444 and this is a good price for a new OPRV
Pelican Parts - Product Information: 944-107-035-11-M100
Did you spill your coffee???
If you do a search on this board you will find instructions on how to test and rebuild the OPRV and replace the 2 "O" rings. (and save the $444)
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 02-28-2011, 06:27 AM
Send a message via Skype™ to massive
GL
John
Check out my blog 944 Foot To The Floor: How to remove and replace OPRV (Oil Pressure Release Valve) on a Porsche 944 for all you need to know on the OPRV
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 02-28-2011, 06:58 AM
John_AZ's Avatar
massive has an excellent write up on the OPRV.
He has a few others if you search as well and are very good.
Like massive says in the DIY, you do not need the alignment tool if you just remove the OPRV. If you replace the gaskets on the oil cooler you do. Pelican does not sell the "late" 944 OPRV alignment tool.
BUT---there are 2 OPRV "O" rings on the OPRV valve. Outter and Inner. Pelican sells both.
Here is a DIY on how to change both.
Information provided for future members who use "search".
TSB 19017
GL
John
Old 02-28-2011, 07:57 AM
TSB 19017
GL
John
Nice update John_AZ, I've updated my blog to reference this post with the new information you put up.
Old 03-02-2011, 02:24 PM
pschaars951's Avatar
Send a message via AIM to pschaars951
hey everyone, I just wanted to verify that the "early" o-rings will work on the "late" OPRV. I am assuming they do since they are mentioned an no one specified they didnt, but I would hate to pull apart my valve and then be stuck for a while.
Also, my valve moves freely, looks fine, but I am only getting 1 bar at idle and can hear the valves. Is it still likely to be the valve? or should I start looking at other things while I wait for my o-rings to arrive?
thanks,
Pete
(if my signature isnt updated: 1987 944S Blue on Cream, SOLD!
1990 944S2 Blue on Cream, on jack stands. Needs rear half shaft replaced and low oil pressure solved.)
was: '85 300 ZX, '87 944 NA
is: '90 944 s2 coupe
Old 06-01-2011, 04:13 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
GL
John
Damn John, you made coffee come out of his nose posting that price. lol
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 06-01-2011, 05:58 PM
kcladnier
John_AZ,
I tried to install the inner O ring in by oiling it, and pressing it in with the O ring fitted onto the shaft. The O ring tore. I ordered a new one. Should the O ring be fitted inside the hex head part or fitted on the shaft during pressing?
Thanks for the info.
Old 05-14-2014, 01:22 PM
John_AZ's Avatar
kcladnier,
Sorry reply many days late, my brain is still 7 time zones away.
I do not know the year of you car. The O ring should install snug and not be damaged when lightly oiled. Did you get the correct "Inner & Outer" O ring for the OPRV?
MORE INFO
I hope you did solve the assembly problem.
J_AZ
Old 05-23-2014, 05:29 PM
ernie9944's Avatar
Just wake up was laying down on the floor,fainted I guess when i seen the price.John have pity on us lol.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 05-23-2014, 06:01 PM
John_AZ's Avatar
Hi ernie,
Glad you're smiling on an old thread. Take care.
John
Old 05-23-2014, 06:13 PM
Tags
oil , oprv
