Send a message via AIM to hpaulb
alternator question
I had mine tested at the local repair place after i shanged the regulator module. Real easy job. They said it was fine. Stored for the winter and the same problem. Puts out around 6-7 volts disconnected from the battery. Shout be full output 13-14 volts. Thinking it may be the startup field voltage line. Think it's the small one the goes on at startup then is supposed to self power. Is this connected to the starter ignition. Anyone work on this problem. Sort of looks that way on the wiring schematics.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 06-04-2014, 09:14 AM
Not related to the starter ignition. Is related to the ignition switch in the run position.
If you get the alternator going fast enough, you don't need the startup field line; the alternator generates its own.
Sounds like a bad alternator... have it tested again.
Good luck, George Beuselinck
Old 06-04-2014, 09:37 AM
