Question Convert small to large offset
I have an '86 NA that uses small offset wheels. I'd like to convert to a later large-offset suspension, partly for wheel availability, partly for greater comparability with M030 suspension and brakes, but mostly for ABS retrofitting.
I have the M456 option now, with Sachs front struts and Koni rears.
I'm not necessarily going to do the full M030 conversion at the same time, unless I can't reuse any of my existing suspension.
What parts do I need to convert my existing suspension to the later large-offset setup?
Old 07-01-2014, 09:55 PM
Volhv's Avatar
I think all you need for the rear is the hubs.
For the front, the control arms are definitely different, and maybe struts and spindles.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 07-01-2014, 11:25 PM
I think I'm starting to figure out the answer, at least partially, is to look at the parts diagrams for a 944 Turbo on 944online.com Find Parts and tools For Your 944, 944 Turbo, 944 S And 944S2. or the catalog here at Pelican and look for the parts that say "87+" in the suspension, steering, rear axle, etc.
Old 07-02-2014, 12:11 AM
9FF 9FF is offline
9FF's Avatar
If you already have the rotors, calipers and struts iirc you also need 87+ front hubs, spindles, control arms, flexible brake lines and for the rear you need caliper spacers, hubs and hard brake lines.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 07-02-2014, 01:41 AM
