Volhv's Avatar
Hatch release mechanism
I have to hold the key in the unlock position when opening that hatch, otherwise it springs back to latched.
Should there be some sort of detent to keep the hatch release mechanism unlatched? Or maybe a spring?
Same thing when operating it with the motor, it unlocks it.... but it springs back to locked.
Not a real issue, but it would be nice to have it working properly.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 07-14-2014, 01:27 PM
It's possible that it's just too loose so it does not pop up. Pins are easy to adjust, just loosed the lock nut and turn then.
Old 07-14-2014, 01:51 PM
Back from Beyond
Normal.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-14-2014, 02:06 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
There's no detent to hold the lock open. The piston struts are the motive force that pushes the hatch out of the receivers when the lock is turned to "open". Your key lock is operating normally. It the hatch isn't popping up when unlocked, then the pins may need to be adjusted. Also a little lube in the capture claws may be in order.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-14-2014, 02:17 PM
Going faster all the time
Litesonic's Avatar
It's amazing what a good clean and lube will do.
With the new struts on mine, I almost need to stand back or the tail will smack my chin.
Now to install the replacement cable so that I can *safely* release the hatch.
Now: 1997 German-built Boxster - Black
Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray
Old 07-14-2014, 04:55 PM
Volhv's Avatar
Awesome, thanks guys.
Put a set of those stainless pins in a few years ago. I adjusted and lubed everything at that time.
I guess my only issue is the blown hatch struts. Thing is, I don't want to replace them since I hear they are the cause for hatch delamination. I got a hinged prop-rod installed to keep the hatch open.
Old 07-14-2014, 11:40 PM
The other thing that causes rear hatch not to 'pop open' is the rubber seal. When it is new it has some spring in it which pushes the hatch up ... when it is old it becomes flat and loses its spring ... like all of us A new hatch seal sorted it for me.
Old 07-15-2014, 01:29 AM
Bradical's Avatar
Where did you get these? One of my pins is broken...
Old 07-16-2014, 04:15 PM
Patrick
pfarah's Avatar
Sounds like it's normal operation. Mine works the same way...
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 07-16-2014, 04:38 PM
Volhv's Avatar
Rennbay, has the stainless pins.
Stainless Hatch Pins for the Porsche 944
The shanks of my rusted pins, sheared inside the square nuts. Drilled and tapped them as a temporary fix, but it's been 3 years now, and they are holding up perfectly.
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
A new hatch seal should be on my to do list.
I've also considered doing a cable hatch release, but that might be too much work, for too little gain.
Old 07-17-2014, 12:21 PM
