Power locks
Just got my Performance Products catalog yesterday. They are selling a power lock upgrade for the 944. Has anybody done this? The manual locks are (grammer police alert-should I use "is" instead. No jokes about the definition of "is" please.) the only thing I'd change on my baby.
1987 944 NA |
Are is correct.
Known a few people that did it, never really heard anything good or bad about it. As a side note - you will still have to manually lock your door with the key. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
I have not tried those, but I used these...
I just installed then today, but they seem to work fine. Not all the hard to install either.
85.5 Red 944 Http://members.rennlist.com/afx |
1987 944 NA Last edited by fc3286; 09-26-2002 at 05:51 AM.. |
Get the 5 wire as it locks and unlocks both sides. Some alarms lock the doors when ignition is on, hassle if you are picking someone up. And the complete kit with harness and relay are cheap and easy to install. I found the lenght of the harness to be just right for my 944.
I bought a power lock kit once. (Still Have it.) But when I got the door panel off I could not find a place to mount the actuator. It did not seem possible. What did I do wrong?
Thanks Thom P.S. It looked almost identical to the ones on ebay.. |
You mount them behind the sheet metal near the rear vents of the door, parallel to the lock knob. You need to drill 2 holes for the screws.
has anyone tried to wire up a different setup?? Maybe two rocker style switches??? than just the single central lock
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
marksportcts,
so the actuators are mounted vertical? Do you drill the holes in the end of the door (vent) or the part the door panel mounts to? Thanks Thom If you want to just show pictures with a 100pg guide on how to do it that would be great. |
no...horizontol ...... the actuator sits pointing to the end of the door (with the vent.)
not on the sheet metal where the door panel mounts either... (your window will hit it) its further into the door behind a piece of sheetmetal (right behind the door handle)... anyone have a pic of this handy.
pic would be fantastic. Or someone comeing to the house and installing them, while I am out coaching my kids soccer game would be even better.
