thekidd's Avatar
Send a message via AIM to thekidd
Ways to remove BB sprockets without pin spanner
Is there a way to remove the 2 balance belt sprockets without the pin spanner? I have all the tools for a TB change, but stuck at the sprockets (have to remove to replace seals, right?)
Old 07-28-2014, 06:24 AM
Andrew Gawers' Dad
CHICKS's Avatar
TEKTON 3492 11-Inch Long Reach 90-Degree Bent Nose Pliers - - Amazon.com
Old 07-28-2014, 07:00 AM
have a friend (or you can do it yourself) hold the old balance shaft belt around the pulley squeezed tight like a strap wrench...it will work enough to get the bolt loose
Old 07-28-2014, 07:09 AM
Custom User Title
mikepellegrini's Avatar
The first time I did a belts job, I did it using two punches and vice grips pliers - you put the punches in the holes and then grab the two punches with the vice grips. I broke a couple of the punches but did manage to get the job done. It was a real PITA.
After that, I bought a proper tool and was amazed at the ease and simplicity of when you use the proper tools.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 07-28-2014, 07:53 AM
Back from Beyond
^+1
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-28-2014, 08:04 AM
Proper Tools FTW!
Good luck, George Beuselinck
Old 07-28-2014, 08:13 AM
Yeah, having the tools makes for a lot of time savings. Even when I spent 20-minutes making a pin-spanner from metal-scrap laying around, it still saved me at least 20-minutes on the belt-change job. And you don't have to worry about destroying your engine because you couldn't quite tighten the sproket bolt enough without a pin-spanner.
Old 07-28-2014, 10:08 AM
Andrew Gawers' Dad
CHICKS's Avatar
It's pretty awesome.... Combo Pin Wrench Porsche 944 Combo Pin Wrench - $52.00 : ArnnWorx Specialty Tools
Old 07-28-2014, 10:51 AM
Love my 944
MicSne's Avatar
I bought a $20 pulley wrench from the local auto parts discount store. I removed the fan belt that was installed in the tool, cut a strip from my old timing belt and put it into the wrench. It works like a charm!
Old 07-29-2014, 09:29 AM
thekidd's Avatar
That tool above looks smart, but I got a spanner on the way. I'll wait to make that tool when my future spanner breaks.
Old 07-29-2014, 01:38 PM
Bradical's Avatar
CHICKS said it, bent nose plyers. Why spend $50 on a tool that serves one purpose when you can spend $5 on a tool that does that and more?
Old 07-29-2014, 04:07 PM
