JBC JBC is offline
JBC's Avatar
Slave & Master Clutch Cylinders New or Rebuilt
I have to replace my slave and master clutch cylinders. The line between the two seems fine and looks good. The line from the reservoir to the master could use a replacement. Rebuild or new? Thoughts?
Looks like ~$155 for new (both units) and about half or slightly less that for rebuild kits.
Old 10-04-2014, 06:46 AM
JBC JBC is offline
JBC's Avatar
Sorry, just did a search and there are many threads on this one. Should have done that first.
Old 10-04-2014, 06:50 AM
flash968's Avatar
i spent 25 years dealing with bad hydraulics on british cars. the problem with rebuilding them is that it is entirely dependent on the condition of the cylinder casting, which you won't know until you put it back together. you could easily go through all the trouble and effort, and have it fail again.
it didn't take long before i learned that it was cheaper to buy new than to do the job twice. the tow truck alone cost more than the parts.
ernie9944's Avatar
Hate to agree with flashbut +1 ,save yourself a lot of problems & buy a new one.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 10-04-2014, 07:05 AM
Patrick
pfarah's Avatar
And don't forget to replace the blue line between the brake reservoir and clutch master cylinder...
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 10-04-2014, 07:34 AM
JBC JBC is offline
JBC's Avatar
I just pulled the slave off and looked at it closely. I came to the same conclusion as Flash without reading his post. I was coming in to see what is included in a rebuild kit first but I was concerned about the casting also and thought it a 50/50 proposition for success. I need to think about it and tear down the current cylinder and make a decision.
Old 10-04-2014, 07:43 AM
flash968's Avatar
yup - i hate doing stuff twice, and i especially hate dealing with brake fluid. my time is worth more than the difference in parts cost, and then there is the cost of the tow truck (if you don't have AAA) and just the hassle factor of dealing with it. the last time i had the 968 towed, a ramp board the driver was using flipped up, smashed a headlight, and dented a fender.
another part to change would be the high pressure line. at least on the 968, it is well known for blowing at the coupling, and frequently does it right after putting in nice new strong components. the pressure finds the remaining old weak part, and then you get to go back in there again.
Old 10-04-2014, 08:59 AM
JBC JBC is offline
JBC's Avatar
Outstanding point on the weak spot. I will replace the line. The internals of both the slave and master a smooth and clean. I'm tempted to rework due to the condition of the inside.
Old 10-04-2014, 04:37 PM
flash968's Avatar
it has been successfully done. having had it fail before, i'm just not inclined to roll the dice anymore. the parts are too cheap, and my time is worth more than the difference in price.
and then there's that whole "tow" thing if you guess wrong. by the way, this was exactly how i got the busted headlight and dented fender. i guessed wrong, the clutch hydraulics blew, and i was stranded on a windy canyon road. lucky i didn't get killed.
Old 10-04-2014, 05:12 PM
I couldn't find a rebuild kit for the master cylinder. Anyone have a source? I saved the cylinder that I took out as the bore was good and I would rebuild it and use it as a spare if a kit was available.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 10-05-2014, 01:31 PM
Bradical's Avatar
When I was bleeding out the old nasty brake fluid when I got my current NA, the slave cylinder literally blew apart. So, I ordered a new one, and while I was bleeding it the master cylinder blew apart. So, I ordered that and the high pressure line, and the motive power bleeder. As soon as I pressurized the motive to 3psi the blue hose exploded and sprayed brake fluid everywhere. Now, whenever I start a job on this car, I buy everything that's within 10 inches of what I am working on...
Old 10-05-2014, 01:59 PM
AFM #725
Gawernator's Avatar
Lmao, that's pretty funny. It's true with older 944's for sure. There's a couple parts I wish I had bought earlier, because you'll find yourself doing the same job multiple times, instead of just buying all the parts and doing it 'while you are in there".
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 10-06-2014, 05:19 PM
flash968's Avatar
yup - over in the 968 group, we've had hundreds of the high pressure lines go. some people would change only that line, only to find that either the slave or master blew shortly thereafter.
hydraulics are no joke. that pressure is huge. degradation and failure originates on the inside too, so you can't inspect it visually. further, the seals and hoses are only rated for 8 years. yes, most of them live longer than that, but many don't, and often because the system was not flushed every 3 years, as it was supposed to be.
i think it's penny wise and pound foolish to mickey mouse around with this one. it's just not that expensive to do it right the first time.
Old 10-06-2014, 05:56 PM
