Question Sender unit switch under intake plenum. What is it?
There is a sender unit switch with two wire connectors under the intake plenum. What is it called and what does it do? The reason I am asking is that there was one connector off and the car was running fine. When I put the wire back on the terminal, when the car is hot and I try to start the car it will idle but when you try to rev it up it will feel like it is cutting off. After about one to two minutes it will clear up and run ok.
Thanks,
Old 08-03-2014, 01:20 PM
ASE Master
alfadoc's Avatar
JFGI
1991 944S2 mystery sensor under intake manifold - Rennlist Discussion Forums
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 08-03-2014, 03:22 PM
Ok, thanks for the info.
Old 08-03-2014, 05:05 PM
