What would Darth Vader do
Lsd
How can I tell if I have a limited slip differential in my vehicle?What do I look for?
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
Short of looking up the option codes, you can look at the top of the tramsmission case -
LSD should be 8Q##### Standard is: QM##### AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Or if your LSD is in good working order you can lift the car in the rear when it's in neutral and spin a wheel one direction...if the wheel on the other side spins the opposite direction you've got a standard 'open' diff. If the other wheel spins the same direction you've got a coveted LSD, and you're lucky.
