Another TDC question
Doing the belts/wp/roller/front reseal on the 944T and finding my TDC marks not lining up. The camshaft timing looks good, but the lower balance shaft and top balance shaft marks are both off.
I cannot read the bellhousing TDC mark by the reference sensors, too much crap in the way. So from what you see, should I be okay to install the flywheel lock? Picture below.http://forums.pelicanparts.com/uploa...1413300989.jpg http://forums.pelicanparts.com/uploa...1413301056.jpg http://forums.pelicanparts.com/uploa...1413301477.jpg |
I think you should find that flywheel mark - I know it can be hard to see so once you find it mark it with white paint - it's just a line across the top flywheel surface and blends in - either your balance belt is off a tooth or your timing belt is - no way of knowing which unless you make sure the flywheel is spot on
It doesn't matter where the balance shafts are at when setting TDC for the cam belt. Look for the TWO flywheel marks and the cam mark.
Still a no go, I checked the flywheel and found the raised line off by 1inch from the starter/bellhousing notch. What's even stranger is I get significant resistance when trying to rotate the engine over at the crank bolt trying to get TDC.
I must be really messing a something up, I should have been done by now. On a good note, all cooling hoses and clamps are replaced, differential fluid replaced, oil and filter done, spark plugs, cap and rotor replaced, so still a good day, but I want to be driving!!!! :eek:/http://forums.pelicanparts.com/uploa...1413320532.jpg |
You've probably tried, but I usually get best results on seeing the flywheel TDC mark with a high-powered flashlight and one knee on the upper strut mount. It helps to have a helper so you can watch for the mark. Some cars have a cover over the inspection hole, so there's that... Strictly speaking, if you are 100% sure that the alignment is on, you could align the cam pulley mark and stick the flywheel lock in. As long as you put it back together the same way, it should be as fine as it was before you started. I'd probably only do that if I somehow ended up with a flywheel with no mark though. |
...For what little it's worth, I've never been able to see the alignment mark through the window on mine (a 951) and have always used the bell housing. |
The only trick with this method is ensuring the cam isn't 180° off when cylinder #1 is at TDC. Not tricky at all, really. |
Also, its certainly the compression thats hanging you up, pull the plugs first. |
--phil |
Object in the hole is a terrible method. Next time you have an engine apart, look how much time the piston spends NEAR the top of the cylinder as you rock the crank back and forth. You could easily be several degrees off doing it this way.
"Too much crap in the way" is a poor excuse not to use the factory timing mark. We've all made it work, just get it done. |
I found if you close one eye and hold a flashlight right next to your open eye it is possible to see the mark through the top of the bellhousing.
http://forums.pelicanparts.com/uploa...1413414181.jpg |
I wish I could say I havent done that before.
Good going, brother! If you havent already, watch Van's video on youtube.
| All times are GMT -8. The time now is 03:22 PM. |
