Sway bar bushing brackets
I'm looking for a new pair of the loop brackets that hold the inner bushings on the front sway bar, that will fit part # 477-411-053-G-M260 (20mm bushings)
My old ones are both corroded and too big for the new bushings, even though they are the right bushings for my car.
If anyone can verify that the brackets sold on Pelican (part # 944-343-731-02-M100) will fit these bushings and aren't bigger like the original brackets, that would be great. Or if you have a pair of good used ones and can send me the interior diameter of the loop--should be right about 35mm when tightened.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928
Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944
Old 11-16-2014, 10:44 AM
I found a great deal on an upgrade to a larger sway bar so I'm going for that.
Old 11-16-2014, 11:52 AM
