Porsche Crest Speedometer Ticking/Jumping
Hi guys,
My speedometer on my 1984 944 NA, makes a ticking noise and the needle jumps when I take off in the morning. The faster I go the more frequent the ticking and needle jumping is. After about 10 minutes or so of driving the speedo gets normal again. No ticking no jumping. Any ideas as to why? I am thinking it may be the cold (freezing or bellow freezing) and stops acting when it warms up?
1984 944 N/A Passadena Gold, No Sunroof
1971 Cuda 440-6, 4 Speed, The Last 440-6 Cuda built, Black
1971 Cuda 340, A/T, Rallye Red
1970 Cuda Ragtop, 383, 4 Speed, Triple Black
Old 11-15-2014, 04:00 PM
plays with toy cars
sausagehacker's Avatar
The speedo cable just needs to be lubed. The cold is inhibiting the lubricating properties of whatever grease is still in there.
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 11-15-2014, 04:07 PM
Patrick
pfarah's Avatar
Sausage is correct, Just remove the instrument panel and (very slowly) apply many drops of chain/cable lube. I performed this 1.5 yrs ago and haven't had an issue since (knock on head several times).
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 11-15-2014, 07:19 PM
