How to know if the reference/speed sensors are broken?
I have been having some issues with getting my 84' 944 to start these past couple of weeks. One night it just gave up starting, it was a very cold and wet night. Since then, I have been trying to pinpoint what is wrong and whatever is going on, it has passed my knowledge of this car.
So When I try to start the car, I can hear the fuel pump so I have a good fuel pump dme.
I have a pressure of 35 psi from the fuel rail, so no fuel issue
I am not getting any spark for some reason, even though I measured the ignition coil and got almost 12 volts from the main terminal. The rotor looked fine, as well as the distributor cap.
Im not getting a tachometer bounce when Im trying to start the engine, which leads me to believe its either the speed or reference sensor.
I channged the oil, oil filter, and gas filter just thinking that a possible tune up may help.
Anywho, how would I go about testing the sensors? Do I pull them out and check for and cracks, or should I take it in to a mechanic who knows what their doing, leaving me to pay a bill?
Old 11-18-2014, 12:51 PM
911tracker85's Avatar
Bad DME or reference/speed sensor?
Josh,
check your other thread link above, I just posted some comments about this.
as I note, you really need an 0-scope to see the crank/speed sensor signals. and when I did mine, I checked at the DME connector to also eliminate the wiring harness.
try the process I and notmyscreenname gave in that thread to see if you are getting toggling of the control lead to the coil.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 11-18-2014, 01:07 PM
