Porsche Crest Looking for a 1989 944 fuel injectors Base coupe model
Hi guys. I recently bought a 1989 944, it caught fire on me while i was driving and i'm looking for 4 fuel injectors. Here is the info of the car:
1989 Porsche 944 Base Coupe 2-Door 2.7L 2688CC l4 GAS SOHC Naturally Aspirated
Old 11-25-2014, 10:40 PM
If you check the Bosch part number it might be compatible with a more common injector
If this is correct:
Références des injecteurs des PMA
Which is supported by this page:
Stan Weiss' - Electronic Fuel Injector (EFI) Flow Data Table
Then the nearby Chrysler injectors might be a good option (3.8L V6). There are even some upgraded 4 hole injectors that might work if this is indeed the case and for less than $100.
I am running 4 hole injectors on one of my 928s, they are newer, cheaper, quieter and probably deliver fuel in a more easily atomized way than the early injectors.
-Joel.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 11-26-2014, 05:35 AM
Any 944NA fuel injector should work.
Old 11-26-2014, 07:25 AM
In the Fires of Hell.....
kdjones2000's Avatar
Not so sure about that.
The same PN is used for the injectors up through '88, but the 2.7L engine calls out a different PN according to PET.
I think that this is a 1-year only injector, so you will need to find the flow rate and impedance if you want to find aftermarket alternatives.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 11-26-2014, 08:48 AM
i found some of earlier year models but all websites said that those NA injectors will not be compatible with my car. I know 1989 was a one year model with a 2.7L engine so its getting so hard to find the injectors. I was wondering if i could use some newer ones or like
Jfrahm said if i could use those Chrysler ones
Old 11-26-2014, 09:16 AM
porschetub's Avatar
Yes they are a differant number,the earlier type will work however,I noticed no differance how my car ran when fitting 85 2.5 injectors to an 89 2.7 engine.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 11-26-2014, 10:43 AM
There might not be a compatible 4-hole as your I believe are low impedance, but going down the ol' rabbit hole leads us to a listing with the OEM part number
Fuel Injector Chrysler 4554044 | eBay
There are listings for 4-hole injectors for that part number, but they might be high impedance. The 911 guys with DMEs I *think* say it is OK to run high impedance injectors and the driver circuit is cool with it. My 928 I put the 4-holes in is LH injection and high impedance originally. These assumptions are assumptions (he assumed) so I would not bank on any of it and I suggest you do your own research.
I suppose that while there are not a lot of 2.7's around many of the heads have been used for 3.0L turbos and thus the original injectors are gathering dust. You might post on a popular 944 turbo forum to find some for cheap.
-Joel.
1987 928S4
1992 968 cabrio
Old 11-26-2014, 11:23 AM
The N/A injectors are a different size that the turbo ones. I have a set off of a 86 turbo which should be the same size. If interested make me an offer.
Old 11-26-2014, 10:57 PM
Sorry I should have been clearer. I was suggesting he post on the Turbo forum for leftover 2.7 injectors from a big turbo build utilizing the 2.7L head. In one of those builds the stock injectors from the head would have been disused. There are probably a few people on the RL turbo board with these injectors as people have either done the builds or are hoarding parts in preparation.
1987 928S4
1992 968 cabrio
Old 11-27-2014, 05:45 AM
